need help, 800 MHz duron problem
zom613
9
I bought a KT7A and a 800MHz duron.
When I boot the computer it says DURON 800MHz(100*8.0)
CMOS checksum error- Defaults loaded. Then I press F1 and continue booting, when I restart windows. The computer reboots and says CPU is unworkable or has been changed. please recheck CPU SOFT MENU. So I go into the bios and it is set for a 500MHz duron I change it so that it is set for a 800MHz duron. I then save the changes.
When the computer tries to reboot the monitor never recieves a signal, my computer is on I can hear the fans and harddrive running but there is nothing displayed on my monitor. To use the computer agian I have to clear the CMOS. When I do that it is agian set up for a 500MHz duron. I don't know if there something wrong with my motherboard or processor.
any help would be appriciated
megatexel
624
Clear your CMOS, load optimized defaults(don't leave the BIOS yet), then setup the options you know what your doing with.
give that a whirl
