Need Help...30 years of building computers but stumped
Shredded_Wheat64
24
4
Computer: Asrock AM4, 5600X, NVME harddrive for OS, 32 gigs Corsair memory, gpu RX 5700, 750watt Antec psu (about 15 years old though), misc harddrives, and opticals. Problem: My keyboard had a stuck key, booted down, unplugged, used friends air compressor when I plugged back in got a no signal from monitor, computer booted up though. Tried everything I could think of, unplugged everything, etc...wasn't until I reseated the ram that it booted...lasted for a little while then nothing again. After continally trying all I could think of it would start booting into the bios but was showing only 1 stick of ram instead of 2, cleared cmos and then bios wouldn't come up anymore and got msg that to install boot media...No idea what is going on and what to do. I did order a new kb/mouse, and a better heatsink/fan. Any suggestions???
Paperdoc
2,523
388
This is a new build, right? Do you understand the proper placement of stand-offs under the mobo? Any stand-off where there is NOT a matching mounting hole in the mobo can cause intermittent short circuits to traces on the mobo bottom. If you need more details, post back.
mikeymikec
21,621
16,897
Yup, age of build would be useful. If the problem persists then disconnect everything that's not strictly necessary to POST / get to a memtest86 test.
daveybrat
5,831
1,044
Seeing as the bios is only recognizing one stick of ram, one of them might be bad. Have you tried just one stick at a time?
Reactions: Ken g6
PowerEngineer
3,615
799
My suggestion is that take this problem to the Computer Building forum. 😄 Note that there are recommendations on what information you should include while describing the problem. Following these recommendations ups your chances of getting help. Good luck.
Reactions: manly
Shredded_Wheat64
24
4
Thanks for the suggestions...yes I know about the stand off mounting, I have tried only 1 stick of ram of my older ram, the computer is about 2.5+ years old. I recently moved over some data from an external portable hd and AVG lit up like a Xmas tree but and still once it was over had problems with the AVG for a few more days then it stopped but was getting intermittent shut downs...the cpu has been running hot and just got a little while ago a better heatsink and fan so will try. I didn't see the computer building forum to post in initially...will look for it. Thanks and anyone else is more than willing to chime in.
Steltek
3,486
1,242
"750watt Antec psu (about 15 years old though)" Time to replace it.
I second this.
Another thing.
@Shredded_Wheat64 , you indicate you used an air compressor to clean the machine out. Did you have an in-line moisture trap installed when you did this?
If you didn't have a moisture trap, you very likely could have sprayed pressurized water all over your motherboard/components, which could have all sorts of consequences.
mikeymikec
21,621
16,897
Also, if the processor has been overheating, then the only relevance that has is because it's been allowed to chronically overheat and thermal shutdown for so long that the processor is damaged. A replacement heatsink is nigh-on irrelevant until the larger issue has been fixed.
(and frankly, the machine should be able to POST without a heatsink).
Reactions: Steltek
Shredded_Wheat64
24
4
Thank You to all the suggestions. I unplugged everything minus removing the motherboard from the case and put it all back together (with a new keyboard/mouse and changed out the CMOS battery though only 2+ years old). I did put an aftermarket heatsink and fan on the cpu. The computer booted straight into windows...only had to go back in to bios to set XMP profile but it has been running for about 5 hours no problem and temps are about 15-25C less. Thanks again...I was really stumped. Later, I will upgrade the psu to about 1000W+ in anticipation for AMD's UDNA GPUs.
Shredded_Wheat64
24
4
Logically the CMOS reset did the trick, I'd say.
I changed the CMOS in the beginning and it was still messing up. I heard a sound as if something was shorting out but heard a sound similar as my computer is off the floor on a hard plastic container. As I said, unplugged everything and majorily did some cable management. Just so weird it stopped working after unplugging a usb keyboard???
