Jennerstein
A month or so before Christmas, my Sapphire Atlantis Radeon 9700 Pro's fan died. Stopped spinning completely. Anyway, I went looking in all the local computer stores for a good heatsink or fan for the Radeon, but all they had was your typical VGA chipset fan. So I bought it as a quick fix. Applied the thermal grease, fit the fan on the core, and plugged in the fan into my power supply. The computer's stable now, although I do get a few artifacts in Wolf ET running 1280x1024 with Catalyst 3.10 drivers.
Because I've been so busy with various projects, I've only now found the time to contemplate finding a proper heatsink/fan solution for my Radeon. I just want a cost effective sensitive cooling solution to allow my Radeon to run all my games at stock card speeds. If I can overclock the card, that's fine, but I'm not buying a heatsink or fan to overclock. I just want to fix the card.
I've done a few NewEgg and Google searches but am not sure where to turn. Definitely will not use the Zalman Heatpipe, since it's already destroyed a previous AIW 9700 Pro I had. It slipped while I transporting the case and mushed the core 🙁.
If anyone could give me some tips, I'd greatly appreciate it.
