need guitar help: trying to play extreme- more than words
khlee
hi, i was wondering if anyone has played this song before and can help me. first, the tab:
Text
im having trouble with the beginning of the second part of verse one:
--0------------- | --------3-0----- | 2-----2---2---3- | --3------------- |
--0---0---0----- | --1-----1-1----- | 3-----3---3---3- | --3---3---3---0- |
------0---0----- | --0------------- | ---------------- | ------2---2---0- |
---------------- | ---------------- | 0-----0---0----- | ---------------- |
--------------0- | --------0-0---0- | ---------------- | ---------------- |
------0---0----- | ---------------- | --------------3- | --3---2---2---0- |
when i play it it doesnt sound anything like it should!! ive been struggling with this for two solid hours. unless i get some help i think im going to give up. 🙁
Um.. Do you at least have the song to listen to? Tabs are useless if you don't have the song right there to play along with. That looks like the correct tabs, tho.
I think the first parts are the easy ones.
I picked up this song from Guitar Pro 3 and the tab that i've downloaded of somewhere. It was pretty easy in the beginning but I can't play the later parts though
<-- n00b
Try to google for the program and the song. If you can't find the tab, drop me a PM and i'll send it to you.
of course
<-- n00b
thanks!! guitar pro is awesome!
this is how i play it
--0------------- | -----------3-0------- | 2-----2---2---3- | --3--------------- |
--0---0---0-1--- | --1------1-1------- | 3-----3---3---3- | --3---3---3---0- |
------0---0--0--- | --0----------------- | ------------------ | -------2---2---0- |
---------------- | --------------------- --| 0-----0---0------ | ------------------ |
--------------0- | ----0--0---0-0--0-- | ------------------- | ------------------ |
------0---0----- | ---------------------- | ----------------3- | --3---2---2---0- |
Originally posted by: khlee
thanks stojaka. btw, do you gusy use all four fingers to tap the guitar?
no...i pretty much just tap with my ring and pinky finger...but i'm hitting the strings with all my other fingers so i guess that helps out the sound too.
Getting the tapping right was the hardest part for me
whats confusing me is that when you listen to the song, the last part of that sounds much higher.. if that makes sense. maybe my guitar isnt tuned right.
