bolitebriga
System Specifications:
I. Processor/CPU: i5 2310-2,9GHz
II. Current Graphics Card: Palit GTX 570
III. Display Resolution: 1080P
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications:
Seasonic 650W
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
Thermaltake V6, it can fit graphics cards up to 30 cm, and more in the hard drive space.
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option.
4000 Kunas, which is about 600 Dollars, no rebates.
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)?
Any manufacturer, I'm running on air, never water.
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
Yes, when I upgrade my Mobo+CPU, unless the next-gen (700, 8000) isn't better as a single card solution.
IV. Have you previously looked at a product(s) which you feel would fit your needs?
HD7950 TwinFrozr III
Sapphire HD7950 w/ boost (dual-x)
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
BF 3, Crysis 3, Skyrim (modded), Far Cry 3, Metro Last Night...
VI. Do you plan on overclocking the card you intend to purchase?
Yes, to about 1100core/6000MHz (effective) memory
Additional Notes
Now, I've read that the TwinFrozr III 7950 comes with bad TIN and usually has a lot of overheating problems and stuff saying the ventilation isn't good, it becomes very load, etc.
For the 7950 dual-x (not vapor-x) I only heard praise, but it becomes very loud at 60% fan speed, but the ventilation and temperatures are okay.
Which one of the 2 would you recommend and why.
Seasonic 650W
Purchase Details:
Additional Notes
