Need Gfx card for Dreamweaver, Photoshop, etc.
masshass81
627
I have a P4 2.4Ghz Prescott @ 400FSB with 2 GB of RAM runnning subject software in addition to other graphic and web design programs.
I always get out of memory errors (IM USING ONBOARD GFX). I'm thinking I need a dedicated GFX card. Would a 6600GT or x600 do the job? Or is there other types of cards I should get for said programs? This workstation will not be used for gaming.
AGP8X cards please. TIA
masshass81
627
Thanks. Then what about a 6200 or x300?
BTW: We are having about 5-6 of said programs open at one time, so I'm hoping a dedicated card would remedy the "out of memory error" despite the 2GB of RAM installed/
volrathy
30
Firstly make sure in your bios you have got more then 32mb of onboard ram set to do the graphics. Make sure it is set it at the maximum.
Secondly a regular graphics card could help . . . but not as much as you might want when using programs like photoshop.
You want to look for a graphics card designed for professional imaging programs
http://www.nvidia.com/object/quadro_geforce.html
This explains the difference bewteen a geforce and a quadro there is a lot memory optimizations. I am reading it myself as I type this and am looking at the "quad buffed stereo" stuff myself.
I myself do a small amount of graphics work in PSP 9 not too much but I am running a 6600gt 128mb version and it just doesn't cut it.
I cant really work with images larger then say 3000x3000x300dpi
I get continual memory problems and the program can sometimes just crash on its own.
I cannot run Dreamweaver at the same time as I am running PSP.
A 6600gt benchmarks between a quadro FX 700 and a FX 500 when using SPECviewperf® 8.1 which is the standard for workstation graphics cards
http://www.spec.org/
My suggestion would be to get a Quadro FX 1100 or a Quadro FX 700 for your requirements the FX 1100 would be perfect
