rh71
I know they locked it to 30fps because it's a port and others have increased it manually but all it does is play the game at double speed if set at 60fps (not true for me - read on). My problem is I'd start out at 30fps and then after 1-2 mins I'm dropping to 10-15fps (from fraps) even though I have literally everything set to lowest, even at just 1280x720 resolution and windowed mode (full screen doesn't change anything).
My system: Radeon 6850, Q6600 quad core, 4GB RAM, Vista64.
It's pretty much unplayable it's moving so slow. I notice Vista64's Radeon drivers are version 13.4 (April 2013) but if I have WIN7 I can get the latest version 13.9. Also they recommend WIN7 anyway. Would this do anything to help me?
The fact that it started ok (not every time) then drops led me to think it was a heat issue - I notice it goes up to 70C under high load. But then I switch over to NFS Most Wanted (2012) and it runs perfectly fine at 50fps+. BF4 runs a bit choppy at low-med settings. But still, I'd expect this to at least run at 30fps. Maybe it's just bad optimization between the frostbite 3 engine and these drivers?
MINIMUM PC REQUIREMENTS
OS: Windows Vista SP2 32-bit
DirectX: DirectX 10
Processor: 2.4 GHz Intel Core 2 Duo or AMD Equivalent
Memory: 3 GB
Hard Drive: 18 GB
Graphics card (AMD): 512 MB RAM ATI Radeon 4870 or higher performance
Graphics card (NVIDIA): 512 MB RAM NVIDIA GeForce 9800 GT or higher performance
Sound card: DirectX Compatible
Keyboard or Gamepad or Steering Wheel
DVD Rom Drive
Online: 512 KBPS or faster Internet connection
RECOMMENDED
OS: Windows 7 SP1 64-bit
DirectX: DirectX 11
Processor: 3.0 Ghz Intel Core 2 Quad or AMD Equivalent
Memory: 4 GB
Hard Drive: 18 GB
Graphics card (AMD): 1024 MB RAM ATI Radeon 6950
Graphics card (NVIDIA): 1024 MB RAM NVIDIA GeForce GTX560
Sound Card: DirectX Compatible
DVD Rom Drive
