giantpandaman2
Hello all,
With the delay in the GPU generations I've decided that it's finally time to stop limping along on my old 4870 and E6600. I've taken most of the parts from the Mid-range build but wanted to switch a few things.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Office stuff, gaming, maybe a bit of FRAPS.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1k-1.3k or so
3. What country YOU will be buying YOUR parts from.
USA
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
ATI this round (I want to pick up Bioshock Infinite)
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None. Will keep old computer around.
7. IF YOU plan on overclocking or run the system at default speeds.
Yes, but I want the computer to be pretty quiet.
8. What resolution, not monitor size, will you be using?
1920x1200. Possibly move up to a 2440 or a 2560 in the near future. (Anyone have a recommendation for a low latency, high resolution, non-TN monitor?)
9. WHEN do you plan to build it?
ASAP (Want to take advantage of any President's Day Weekend sales)
Here's what I have so far.
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
$229.99
CORSAIR Vengeance 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M1A1600C10
$47.99 $47.99
ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
109.99
Fractal Design Define R4 Titanium Grey Silent ATX Mid Tower Case
109.99
PowerColor AX7970 3GBD5-2DHV3 Radeon HD 7970 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
$379.99
SeaSonic G Series SSR-550RM 550W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power ...
$105.99 -$16.00 Instant $89.99
SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Internal Solid State Drive (SSD)
$109.99
Seagate Barracuda ST2000DM001 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$129.99 -$20.00 Instant $109.99
XIGMATEK Dark Knight II SD1283 Night Hawk Edition CPU Cooler with Stealth Aerospace Industry Thermal conductive ceramic coating ...
$51.99 -$17.00 Instant $34.99
Noctua NF-P12-1300 120mm Case Fans
$26.99 -$2.00 Instant $24.99
Total ~ $1250
Noticeably absent is a case. I want a quiet computer and would love to be able to buy a quiet case like the Deep Silence. Unfortunately I don't know a good place to buy it here in the US and don't know what the preferred alternative quiet case would be.
I'm up for suggestions on changing anything. I really want to find a good balance of a quiet computer mixed with mild overclocking. Hence the upgrade to the Seasonic PSU. Is 550w enough? Will not ever be entertaining going Xfire or SLI. Will likely add a few hard drives over time, though.
Is it worth it for me to get a fan controller? It seems that Dustin is a big fan of them in his reviews.
Oh, and is it worth it to get a discrete sound card anymore? I use a full analog out to receiver 5.1 setup at the moment. Things gotta sound good.
Thank you for your help!
EDIT-Added case, changed motherboard and ram to match.
$1k-1.3k or so
USA
$229.99
$47.99 $47.99
109.99
109.99
$379.99
$109.99
Total ~ $1250
