Need fan controller/temp display that automatically throttles fans for speed based on temps
jeeplaw
119
I'm on the verge of getting my new build up and running, but with this 820d that I'm using on my Abit board, you know I'm going to be oc'ing :D
That being said, I had thought that the aerocool gateway fan controller would be the ideal device to control my fanspeeds based on system or cpu temps. But from the reviews I've been reading, the "auto" adjust hasn't been so "auto".
Does anyone have any experiences with a unit similar to the Gateway that allows for auto throttle adjustments based on temp?
jeeplaw
119
Just read a ton of reviews on the flakiness of this unit..anyone know of something similar, but is more stable?
GalvanizedYankee
6,986
Check this one out, it will display on the monitor.
Frozencpu also stocks several other high-end controllers. Look at what performancepcs and maybe jab-tech have on hand.
...Galvanized
Forgot...Tas has a Hardcano 13. He might post in the PM.
Operandi
Why bother with a clumsy hardware controller? Just plug the fans into the Abit board and let it control them.
jeeplaw
119
I was shooting for a cool factor, plus the one touch feature if I need to reach onto the front panel control and manually adjust something.
Unkno
1,659
or use antec psu, most of them have fan connectors that automatically adjust the fan speeds according to the the usage of the power, or just use an asus board with Q-Fan....
