Im currently in escrow to purchase a home that was built in 1959. Hired a home inspector yesterday and he found the wiring in the home is not up to date. The outlets has the 3 sockets but when you go into the box the ground wire is not connected. The whole house is like this and even in the bathrooms where GFCI outlets were installed but does not work because of no ground wiring.
I don't plan to do a DIY project on this because of safety issues, most likely will hire an electrician to do the work. But I just want to know if this is something hard to fix and I am wondering if anyone else had experience similar to my situation. How much does it usually cost to fix a problem like this. I will call couple of electricians in the next few days to get an estimates, but just wondering if I could get an answer here also.
The home I am purchasing is around 1500 sqft, single story, and there are probably around 13-15 outlets throughout the house.
*latest update*
So the seller agreed to give me $8500 (asked for 17k in credit). should I take it and run? or as for a little bit more...?
*update*
I have contacted several electrical repair companies and also spoke with my electrician friend. They all gave me an estimate, without looking in the house, of at least more than 10k to fix the problem. I will request the seller to credit me 12k for all the repairs around the house, hopefully the seller is nice enough to accept my request.
Does anyone have any experience with writing a buyer request for repairs/credit letter? Here is my draft, is this the right format and does it sound convincing? (maybe I should start a new thread for this):
Dear Seller,
Numerous deficiencies were identified during the home inspection, but several items stood out as major problems that will require repairs.
1. The outdated electrical outlets and panels are not grounded. Three prong outlets were installed in the outlet receptacles but no grounding wire is attached to the grounding port of the outlets. GFCI outlets are found to have been installed in the bathroom outlet receptacles, but grounding wire is not attached (GFCI outlets will not work without ground wire). Electrical panel is missing grounded branch circuits. The current electrical code requires updated wiring and also requires grounding wire to be install in all electrical panels and outlets throughout the house. Outdated wiring and the lack of grounded outlets may lead to shock and fire hazards to the occupants of the home. I take the safety of my property and my family members very seriously, therefore I request this problem to be fixed before I will let my family to occupy the house. Furthermore, the outdated wiring in the home will stop me from performing any renovations to the kitchen or the bathrooms as contracts will not work on outdated circuits.
2. Termite damage is found in numerous rafter tails on the roof. The damaged rafters requires repairs because this problem affects the structural integrity of the house. It is unclear as to the extent of the damage because the attic portion of the rafter were not inspected (detailed termite inspection was not performed). Damaged rafters may lead to the collapsing of the roof so this problem needs to be repaired. Since this issue deals with the structure of the house, a licensed contractor will need to perform the termite damage repairs.
3. Main roof shingles are worn and show signs of weathering. The roof shingles appears to be at the end of its useful life. When the roof shingle fails, rain water may enter the house through the roof and cause property water damage and may cause fire or shock hazards if the water come in contact with any electrical component.
The seller is requested to either fix the deficiencies described above or credit the buyer a total $12,000 so licensed contractors can be hired to repair these problems. Please note that the cost to perform the above repairs will most likely cost more $12,000, but I requested for this amount because I believe its an amount we both can work with.
*latest update*
*update*
Dear Seller,
