Goosemaster
the end connector (which I connect into an ipod or cd player) had gone bad and would only work in mono. I could twist it a little bit and get stereo, but in the end it got too loose, so now I am trying to fix it...
I sliced the end connector, stipped off the external insulation and found three insulated wireless wrapped in copper wiring.
One is blue, the other is white, and the final one is yellow.
I also stripped the end connector off of a nice quality minijack cable and have my usual red and whites.
Basically, I want to tie them up together and solder them together. On the transmitters wires, I need to know which one is ground so I can guess left and right...
I'll hopefully get a chance to experiment tomorow but I wanted to ask jsut in case the day stretches out and I do not get a chance.
Thanks
wireless transmitter
-----| Yellow
-----| White
-----| Blue
Thanks
-----| Yellow
-----| White
-----| Blue
