GeekDrew
No Cliff's.
Relevant Information:
My family owns three farms. On the largest of the three are two barns. One of them has electricity running to it.
I replaced some of the wiring in that barn a few years ago, because it was older than stone, starting to fall apart, was very dangerous, etc. All I wired in that particular barn was a few outlets and a few lights.
I also noticed that the wiring that ran through the barn, and then outside and to the well water pump was also looking worse for the wear. It was years and years old. It runs from a fuse panel inside a block milking parlor, protected from the elements, out a pipe (henceforth, exposed to the weather, in some fashion), through a barn (ran along some support beams), down a wall, through a hole in a sliding door. There's a grounded extension cord plug on the end of this wire.
There's a block enclosure about 5 feet away, where the water well is. There's a power cord running from the pump up into the block enclosure, out a hole, and it has a plug on the end. Previously, we'd make sure that the plug was always plugged into the socket, and we would turn the pump on and off by screwing/unscrewing the fuse in the panel. I have no idea WHY we did it that way, it's just the way it's always been done. There's no pressure tank or pressure switch on this pump. I *think* that it has a 3/4 hp motor on it.
Apparently something happened to that wiring last fall, and the people who are using our barn right now temporarily ran a heavy duty extension cord from the pump enclosure to the barn, and to an outlet. I didn't know this until like two days ago. So, when I showed up and needed to fill a 200 gallon chemical tank 3/4 full, I discovered the wiring change (since I couldn't figure out how to start my own water pump any more). I pumped the tank to 145 gallons (something like that), and walked back to the outlet... when I grabbed the plug on the extension cord, to unplug it, I pulled my hand back away, because it was so hot... I eventually just grabbed it quickly and yanked it out... in the process, one of the prongs on the plug touched my pinky finger... I've still got a mark there from it... it was the worst burn I think I've ever felt (and on the farm, I've played with fire, hydraulic oil bursts, overheating engines... a lot). I think it was Wednesday that this happened.
I ran like a madman to a neighbor's house, to see if I could get a cold compress or something for my hand (and I needed to wash my hands anyway, I had RoundUp on them). After running my hand under cold water for a while, I went back outside and explained to him what just happened with the pump... so he came back down to the farm to nose around with me. He owned the farm before my family bought it, so he knew the way everything was wired, except for the changes I made recently.
We concluded that the wiring definitely needs to be replaced between the fuse panel and the pump enclosure.
Now for the question:
What would be the best way to replace the wiring from the fuse panel to the pump enclosure?
My thoughts on the issue: I want to put in cable that is rated for burial where it is outside of the barn, and is completely exposed to the weather. That would probably be from the junction box inside the pump enclosure to the inside of the barn - eh, 20 feet or so, and that's giving me plenty of slack. From there, splice that cable with indoor cable, just so its less expensive (or I could possibly run the underground rated cable the entire way), enter the milking parlor, and connect it to the fuse panel. What I need to figure out how to do, though, is add the ability to switch it from two locations (a three way switch), and add status lights at both locations. Is there any reason that I should *NOT* put three way switches into the mix? The only reason I'm asking is because I've never worked with electricity when I was powering anything that had a motor on it. I know that you can connect many motors to just about any circuit, but because I have relatively little experience with motors altogether, it's better for me to ask than not. Also, is there any special type of switches (other than just the regular three-way-switch from off the shelf at Lowe's) that I should get?
TIA, I feel like a complete newb here. 🙁
No Cliff's.
No Cliff's.
