- Dec 26, 2004
- 11,905
- 148
- 101
Question: An op amp is being used with an open loop gain of 50,000 an input impedance of 3M ohm and an output impedance of 80ohms. Assume that it is being used in a non-inverting amplifier with a feedback resistor of 68K and an input resistor of 10K.
1) Calculate the closed look input imedance.
Would this be Ri + Rf/50,000? I'm pretty sure it is, I'm just making sure. I'm coming out with 10.001k ish.
2) I'm having a problem with: Calculate the closed loop output impedance.
I thought that Zout = Zout / (1+Open loop gain x B) ? And I thought B was = R1 / R1+ R2? Am I doing this part right? Cause I'm coming out with a weird number.
3) Calculate the ideal closed loop gain (assuming an ideal op amp were used)
Didn't try that one yet, but you're more then welcome to
If you could help.. I'd appreciate it. Thanks
