need easy way to put names of mp3 on something, can you help?
gplracer
1,768
37
I am backing up some of the files of demos and mp3's that I have downloaded. I have so many it would that it would be real time consuming to make labels for them. Is there a way to take the list in windows of the programs and print it? It sure would make life easier. thanks
JERR
348
the print screen button will place a screenshot on the windows clipbard, which can then be pasted into a document such as word. Or do you need to create an editable list?
Ladi
2,084
In Winamp, open the Playlist window, the click twice on the "misc" button and select "Generate HTML Playlist"
~Ladi
