Need DVD/CD help!!
joepa99
101
I just installed a DVD Burner on my comp, as well as an additional 80GB HD. Now I am no longer to burn cd's on either my CD-R/W or my DVD-R/W.
When I went to Device Manager, it shows both drives as SCSI devices, which I know isn't true. I checked in the BIOS, and it is showing them as IDE.
I have an Epox 8rda+ motherboard.
Any help is greatly appreciated!!
tm37
12,436
How do you have them set?
Master/Slave I am guessing on the secondary channel?
Did you double check the jumper settings?
polloloco
32
Try hard setting the jumpers master slave on the 2 optical drive and put the hard drives on the same channel
joepa99
101
I found out what it was. It seems that the Nforce IDE unified driver has some bugs
