C CrumCake Senior member Nov 10, 1999 571 0 0 Apr 21, 2001 #1 I had a dual boot with 98 and win2k. So i wipe 98 and load WinMe and now the bootloader is missing. How can i get the option to boot into win2k back? WinMe is on C:, Win2k on D:.
A AKA Golden Member Oct 10, 1999 1,304 0 76 Apr 21, 2001 #2 Start reinstall of Win2K and choose REPAIR
J jj1492 Senior member Jan 23, 2001 241 0 0 Apr 21, 2001 #3 Find the boot.ini file and edit that. You should be able to figure it out.
D ddiccico Senior member Jan 10, 2001 798 0 0 Apr 21, 2001 #4 you don't need to reinstall 2k, just boot from the 2k install CD, choose repair (from console) at the command prompt type fixmbr
