Ok i got a computer running windows XP. It has 2 network cards. One is uses for on a LAN for a invintory and POS system. The other connection is a wireless system that is used to connect to the internet. The wired lan system uses a static IP and gateway so I set that up. and it works ok. Then I install the wireless card and then try to use it to get to the internet it wont connect unless I disable the wired connection. What do I need to do to get them both to connect. Is there anything I can do in windows XP to make it use the wireless card to connect to the internet.
Thanks for any help
Mike
Thanks for any help
Mike
