Need discreete math help!
shikhan
834
Hey guys, i'm a little baffeled by a few questions, if you could give me some tips on them:
1) [Solved!!] -> still working on 2 tho. I've got part b and a foot hold on a but... stupid big oh makes no sense
Let H(n) = sum(1/k,k,1,n)
Prove using induction that sum(H(k),k,1,n) = (n+1)H(n) - n
I started working this out but started to fiddle with both sides and that screwed up the proof the first time. Afterwords, I just get stuck. I know induction is prove base case [in this, base case is when n = 1] , then assume f(n) is true and prove f(n+1), but i can't get anywhere on this one... grr
2) Define f(n) ~< g(n) if f(n) is in O(g(n)). Define lg(n) as log base 2 of n. Define log(n) as log base 10 of n
a) prove that n lg(n) ~< n ^(10/9) but n^(10/9) is not ~< n lg(n)
b) Prove that log(n) ~< lg(n)
I kinda understand big O. I know that its defined as: if g(x) is the big O of f(x), then f(x) <= c * g(x) for some constant c, with x>k for some k
But i have no clue where to go from here... bah
CSoup
565
Are you CS? Sorry, been too many years, so I'm very rusty on this stuff and my brain is very tired right now. I'll look at it if I have some free time.
2a) not sure if you have the ~< in the right direction in this one, but something like the following might help.
for n > 0
if you divide by n on both sides you get lg(n) ~< n^(1/9). lg(n) = k, where 2^k = n => k = n^1/2.
You end up having root functions on both sides, but the left side is always larger for n > 1.
2b) is pretty easy I think. You know that lg(n) and log(n) are different by only a constant from the equivalence formula log base k of n = log(n)/log(k).
These are nice ones, normally you have to do induction to prove these O, theta, sigma things.
yodayoda
2,958
ok, here is what i got for question 1:
Step 1: Prove the base case (in this question, the n=1 case)
(replace n everywhere with 1)
sum(H(k), k, 1, 1) = (1+1)H(1) - 1
(reduce k from 1 to 1 to k=1)
H(1) = (1+1)H(1) - 1
(now calculate H(1) = sum (1/k, k, 1, 1) = 1/1 = 1
1 = (2)(1) - 1
(reduce and clean up)
1 = 1
Step 1 complete--this is a true statement
Step 2: Assume true for case n
Step 3: Prove true for the n+1 case
(replace n everywhere with n+1)
sum(H(k), k, 1, n+1) = (n+2) H(n+1) - (n+1)
(factor the left term, remove the n+1 case)
sum(H(k), k, 1, n) + H(n+1) = (n+2) H(n+1) - (n+1)
(subtract an H(n+1) from both sides)
sum(H(k), k, 1, n) = (n+1) H(n+1) - (n+1)
(reduce the H(n+1) to a H(n) and the (n+1)th term of its sum)
sum(H(k), k, 1, n) = (n+1) (H(n) + (1/(n+1))) - (n+1)
(n+1 and 1/n+1 get reduced to 1)
sum(H(k), k, 1, n) = (n+1) H(n) + 1 - (n+1)
(the +1 and the -1 term cancel each other out)
sum(H(k), k, 1, n) = (n+1) H(n) - n
(look familiar? it should, it is the nth case that you assumed true)
QED
yodayoda
2,958
ok, i formatted it so you can read it. i would work on the others but i have to go to bed. GL!
shikhan
834
YodaYoda!
Thanks alot!!
I saw my mistake finally... I didn't change the statement into double sums, just kept it a sum of a function... Slipped my mind. Thanks alot!
