Case - Evercase 4252b
http://www.newegg.com/app/ViewProductDesc.asp?description=11-127-028&depa=0
CPU - AMD Athlon 64 3000+
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-425&depa=0
Mobo - Epox 8KDA5+ (what is the difference between a3 and a5? 2x or 3x dimm?)
http://www.newegg.com/app/ViewProductDesc.asp?description=13-123-218&depa=0
HSF - Thermalright slk-948u w/ 80mm panaflo l1a (undervolt 5v)
Ram - Geil Value Series 512MB DDR PC-3200
http://www.newegg.com/app/viewProductDesc.asp?description=20-144-305&depa=0
HDD - Samsung 80GB 7200RPM SP0812C
http://www.newegg.com/app/ViewProductDesc.asp?description=22-152-018&depa=0
I will be changing the case fan out of my computer with another panaflo l1a (undervolted 5v), thinking i will try to put a smart drive enclosure on the hdd and some acoustipack padding in the case. Another thing I was thinking was either switching the fan out of the ps that came with the case or buying a seasonic super tornado 300w. thanks for all your help - my main concern is mainly noise - 🙂
