Need CPU fan advice
dj4005
I recently worked on a friend's aging computer. While I got them up and running, I noticed that the CPU fan was somewhat noisy and suggested that replacing it might be a good idea. Now that it's no longer here, I realize I don't know what fan I need.
The computer is based on an old 350 Mhz Pentium II in a Slot 1. It has the original heatsink and fan.
Does anyone know what size fan I need to get? Any specific reccomendations?
Thanks in advance
measure the distance between the screw holes for it. probably be a 40 or 60mm fan, likely any medium speed fan for the size will do.
Most all fans and heatsinks are labeled as to which CPUs they fit. Just read the labels when you shop.
