Need CHIPS B65554 BGA Video Chip (Asailant Technologies) HELP!
merlocka
2,832
1) why don't you contact winbook and get a new laptop? if the part was mounted incorrectly, it never worked properly and the laptop should be under warrantee.
2) if you get a new part (and you get the correct one) how are you going to mount it?
RamonetB
36
The laptop is nearly 4 years old, bought third hand, and is by far no longer under warrenty. So that isn't an option. As for buying another laptop, why spend something like $500 for another laptop (I'm in no need of too much power) or 1000 from a store when there's the possibility of fixing this one? Especially for 10cents.
I am also aware of the fact that you can't solder a BGA chip on. So how am I going to mount it? I have a few ideas, most foremest is that there's a heatplate that sandwhiches the current chip between the board and the itself. I may not be able to solder it on, but I may be able to keep it in position anyway.
Yes yes, I know, hard to believe, crazy ideas and probably won't work. But if I can get this chip for even a few dollars, I think it's worth a try.
