For cheap 250w it's tough to get better than this Sparkle 250w power supply for 5 bucks. Then you can get whatever cheap case without having to worry about whether it has a PS or not.
Yep, even a refurbed Sparkle is going to be better than anything you are going to get in a $20 case (even if it says 800 jiggawatts), plus you might get lucky and find a $10 case with no PSU 🙂
