Need Car Wash recommendation, that is NOT Zaino...
Chunkee
10,391
I cannot afford zaino. Anybody use something else that is gentle and works good without stripping the polish off?
thanks
JC
CChaos
1,586
I'm kind of cheap in this regard as well and I found a bunch of Megiuar's stuff at Costco for $20. I got car wash, wax, quick detailer and a couple of other things. The was alone is usually $8 iirc.
Triumph
14
what are you referring to? as far as I know, zaino doesn't make a car WASH. they make polishes and waxes, but not washes. if you want some carwash, pick up some meguiar's gold class car wash soap at target or whatever. don't bother with the "wax while you wash" garbage from turtle wax and the like.
