Need "budget" PSU advice
SunnyD
Belgian Waffler
Jan 2, 2001
32,674
145
www.neftastic.com
Well, so far so good with the HIPRO. It came in today, nothing fancy. Sturdy construction though, and the annodizing didn't scratch when I installed it.
#1 - It has a LOT of connectors. Too many in my opinion. :) In any event, it has a 20+4, a 4 pin 12v, 2 sata, 1 PCIe, and a host of 4 pin standard molex. It does only have 1 of the smaller floppy power connectors, but that's not an issue for me as I have nothing in my system that uses it.
#2 - On power up, I checked out the the voltages in the BIOS for a bit - +12.10, +5.04 and +3.33v pretty much rock solid stable. I still have to check under loads.
eplebnista
24,123
36
Thanks for the update and info! :thumbsup:
dBTelos
1,858
SunnyD, those voltage readings mean nothing, the chance of them being accurate is very small.
-dB
SunnyD
Belgian Waffler
Jan 2, 2001
32,674
145
www.neftastic.com
-dB
And everyone checks their system using a multimeter and a load tester right?
Temp readings from a motherboard's sensors are usually well off, but voltages are MUCH easier to pin down.
