- Apr 21, 2005
- 400
- 0
- 0
I need an ATX case with the psu mounted at the bottom, you'll see why in a sec. I want to drill at least 2, maybe 3, 120mm blow holes on the top. I plan on attaching a 3 X 120mm Radiator onto the bottom of the new 120mm fans. This puts my radiator & fans at the top of my case, so far no problems right? Not quite....
The radiator I have is GT360 X-flow. The 2 barbs are on either side far away from each other. The problems is the left side barb comes down right into my PSU thus making it impossible to hook tubing up to it.
Found a pic of just what I want:
http://img254.imageshack.us/my.php?image=g70mod120yt.jpg
Notice the 3 fan grill at the top with radiator directly below them. Too bad its a $200 Lian-li
I figure that with the psu out of the way i'm in the clear. the only other detail is that i'm gonna need an extra 1 or 2 5.25 bays so that the right side barb and tubing have enough room to make the angle towards the center of the case down to the cpu area.
So, case suggestions? I figured most of you would suggest antec p180/b. Any others? I'm not too sure about the p180 (for my needs)...
OR, does anyone see a workaround for my dilemna that I migh be missing? Maybe i'm thinking too hard.... thanx
p.s. I consided mounting radiator at bottom but the tubing then gets in the way of expansions slots.
