Originally posted by: Dorkenstein
Does the 4870x2 only outshine a 4870 on larger monitors? I have a 22" Diamondtron from Mitsubishi and usually play at 16x12 or higher if I am able. Would a 4870x2 be overkill or a smart investment for next years crop of games? Thanks.
You should be able to use 2048x1536 on that monitor, right? Not as intensive as a 30" widescreen LCD, but more than enough to tax a 4870x2 if you crank settings. In fact, it might provide a better balance of pixels and settings than a 30", both in today's games and in the future. Plus, better pixel density, and 80+ fps.
Of course if your monitor can't do that resolution well (at least 72Hz and not blurry) then it's time to upgrade.
