BonzaiDuck
- Jun 30, 2004
- 15,877
- 1,548
- 126
My HAF 912 will still fit a 120mm...Better than nothing :-/
Generally speaking the HAF cases all get great reviews on newegg. I'm assuming these people are running tests to see what their temps are.
Also Charlie, you've got to take into account the air temp that you're actually pulling in as well. That will make a large difference..But it seems like in your example, switching cases helped.
I actually work with a bunch of engineers (I'm one myself) and I can ask them if theoretically more open space would be worse. Based on my limited knowledge, I would say it depends. It's more about how impeded the airflow is...and probably less about the "openness" of the case.
No disagreement there. You have any number of options that won't "ruin" your case if proceed with care. For instance, you could pick up a spring-loaded punch to mark the points to drill numerous, evenly spaced holes that would widen your side-panel vent and convert the 912 to a 922. Pick the right 200mm fan and drill mounting holes for it.
On the size or interior capacity of a case: Larger doesn't necessarily mean better if you've merely created a large reservoir of air with dead zones. Whatever the case, whatever the cooling strategy (air or water), you want to push air over components that generate heat. The narrower the aperture, the greater the velocity of air-flow, the better the cooling. And that can be done in very close confines or a more compact case. But with less space, it takes perhaps more thought, planning -- trouble.
