- May 17, 2008
- 10,009
- 66
- 91
My GPU is over heating while gaming. I'll likely need a new GPU but for now I'd like to try and lower my temps to try and extend the life if I can. I currently have a HAF912 with the stock fans (120mm, front and back).
The case can be fit with either 2x120 front or 1x200 front, 2x120mm top or 1x200mm top and a 1x120mm side. I was thinking about buying these Cooler Master 200mm Megaflow case fans to lower my temps. One on top as exhaust and one in front as an intake. I'd move the current 120mm to the side.
I'm wondering if these 200mm will actually fit in my case. The spec section of the fan doesn't list the HAF912 in it's case list and I've seen a few people commenting that the fans would not fit for them. I'm guessing the 120mm's will likely fit, but I'll end up with a super noisey case without much gain in flow. However, these Cooler Master 120mm come in a value 4 pack for $16, and would be all I need, as opposed to spending around $50 for the 200mm's.
What would be the best choice?
