Need best recommendationf on a cpu cooler using a e6700. Plan to try and o/c to 3.4 / 3.6 on air cooling. I have a asus p5b deluxe mobo. I used a antec sonta case so im lookign for somethign that fits. I am trying to get the best cooling possible.
I read up on all those Coolers and there a pain in the butt to install. Scythe Infinity, says its not even supported on there web sight. Is it possible to get one of those bad boys on installed on my motherboard?
