What kind of thread is in the terminals of an OE battery for a 2005 CTS?
Stupid thing can't be connected to any jump starter or charger unless the car connectors are on but the car has lights on and I can't turn them off
Drained overnight and not sure how as nothing was turned on when ihot back into the car
I'm going to see if I can get some screws to screw in so I can hook up my charger but I dontbhave the tools to check the thread
E battery terminals are the kind that have female threads only
Sorry in rush
REWRITTEN POST BELOW:
I need to figure out what the female thread is, on my 2005 CTS OE battery's side-post terminals. The only way to connect anything to the battery is through the OE battery connectors which are "three-way": male thread to go into the battery terminals, cable to go to the electrical system, and hex head for tightening (and alligator clamping). I want to charge the battery after taking it out of the car, because there is a draw from the cabin lights which I can't turn off, but I can't hook up my charger because it doesn't have male threads and there are no posts to clamp onto. If I can get the right screws I'll put the alligator clips onto the heads of those screws and charge it with my CTEK.
I'm not sure how the battery drained, but when I got into the car, everything was dead. No juice to even power the door lock solenoids or trunk solenoid. What was strange, though, was that the overhead cabin lights were on (dimly) and I couldn't turn them off (the manual switches and the main light slide-switch weren't working). I don't know if those lights are to warn that the battery is dead, or if those lights got turned on after I got out of the car overnight and drained the system that way.
Last week I had someone change my aftermarket HID system, replacing all the bulbs and ballasts, but I don't think they would've accidentally shorted anything? Would a bad ballast draw power even if the lights aren't turned on?
Sorry in rush
