i'm listening to some songs for a class that i have... but they're .ram files, and i'm playing them off the link... is there any way to save the file in a format so i can listen to them without being connected to the site...?
bump.... midterm tomorrow morning... i'd like to see if i could get it before a couple hours before the midterm when everyone will be trying to listen and i won't be able to get through
I believe Real Audio has an option of saving it to cache before playing. I remember using it for that purpose before... Its somewher eunder setings, I believe 'Performance'?
i have one of those sb live drives that comes with some software that allows me to record whatever's coming out of the computer at the time. i just check that setting and use a program to record, then convert to mp3.
