What does someone here know about installing Redhat on a Nforce Asus motherboard?
I installed windows to make sure the system worked so I know it runs.
Now I removed windows and am trying to run Redhet 7.3 and when it didn't take I tried ver 7.2 and it didn't take and had basicly the same message problems.
One problem I run into is that Redhat doesn't autodetect the video so what do I set that to I have tried it different ways and it I can't get the combination right or something.
An example of this is when you press the button to test the video output you would like it shows a black screen.
My monitor is a Viewsonic P810-4.
Now another problem is that when I try and start the OS it says can't load into memory and gives some errors and a code ummm 24 I think.
If I can get this computer running it will be a 1600+ on the DF
muttley
Other options are open to suggtestion of using a different Linux type since I have only seen Redhat in any depth, as long as it is known to work with this motherboard.
muttley
