Need answer quick - Radeon 8500 cooling
mrzed
I am passifying my 8500le. I ebayed a large heatsink to replace the stock whiny 40mm HSF. Thing is, there is a raised ridge along the centre of the new HS. The result is, that it covers only about 95% of the GPU core. There is a strip along either edge of a little less than 1mm where there is no contact.
Other than this, I am positive the new HS is more than up to the job. Should I be concerned about this lack of coverage? I have heard that with GPU's the centre of the die is where things get the hottest.
Edit: Nevermind. I got impatient. I'll find out soon if there's a problem.
