Need an explanation of RAW & FAT floppy formats
wpshooter
Can someone give me a simple layman's explanation of the differences, if any, of the RAW & FAT file system for floppy diskette formatting ?
I have done a search on this but I am still not sure if there is really any difference.
Is it O.K. to use floppy diskettes that are RAW formatted on a Windows 2000 or Windows XP operating system computer or should the diskettes used on these system be FAT file system diskette formatted ?
Thanks.
FAT is microsofts way of formatting a floppy. I believe floppys use FAT12. RAW is usually a custom format, could be anything. its sorta like an image of the data on the floppy.
Im not 100% sure on this however.
I *think* "RAW" is just what Windows reports the file system to be if it can't figure out what it is. 😛 FAT works with all flavors of Windows back to Win95.
FAT on a floppy should work all the way back to DOS. FAT32 compatibility starts with '95.
