- Feb 8, 2001
- 35,461
- 4
- 81
Originally posted by: IamElectro
your good to go, but you only want to use the switch to only break one leg of the power with the switch and not both.
Plug here}=======-------------------to lights
this is here for space\____switch here_________to lights
Originally posted by: shuttleteam
Single pole switches ALWAYS break the hot (black) line! NEVER wire a switch ACROSS the line!
Cheers!
Cheers!
So just wire the blacks to ground?
Cheers!
Yes and use the switch to break the white
Cheers!
k, do I need any fuses or anything? Each of the bulbs are going to be 250 watts
Cheers!
Just make sure the switch and wires you use can handle the power 12-14 gauge at least for the wire.
What type of bulbs are you using, and what is this for? 750 watts of total power is a lot of light.
If you like sparks!
The ONLY conductor that should be bonded to ground is the neutral and that is in the panel!
This is a simple parallel circuit. You have a black wire, white wire and bare wire or if insulated it will be green. That is your ground.
The black wires go to bronze screws, white wires (neutral) go to silver coloured screws, and ground goes to green coloured screws. The black and white go to opposite sides of your fixtures. If the fixtures have ground terminals, attach your ground wire there. The switch breaks the hot (black) wire only. The neutral does not connect to the switch at all.
Cheers!
Cheers!
growing pot?
seriously, assuming you get the circuit wired correctly, you risk starting a fire with bulbs that hot inside.
Cheers!
Cheers!
Oh boy!
This is going from amusing to dangerous.
Good thing houses have breakers.
growing pot?
Ha! That's the first thing I thought of. But we all know that incandesant bulbs produce too much light in the red spectrum and too much heat.
growing pot?
FYI, they make something called Grow lights...Check your local hardware store![]()
Originally posted by: Pepsi90919
you obviously have no idea what you're doing.but good luck
Originally posted by: Iron Woode
Lets see if I got this right:
You want to hook up (in parallel) 3 lamps that are wired to a switch (switch fed) that is connected to an extension cord plugged into a wall socket.
Have I summed this up correctly?
You do understand you are in violation of your state's electrical code?
You are not supposed to use a extension cord in that manner.
I assume the fixtures will be mounted to boxes in the ceiling, right?
Now back to the wiring issue.
The switch interrupts the black line only.
The neutrals need to be joined together then pig-tailed off to each neutral attachment on each lamp base.
The black wires need to be joined and pig-tailed off to each live attachment on each lamp base.
The gounds (copper) need to attached together and grounded in a properly mounted box.
Some lamp bases can support 2 sets of wires, in that case, you can branch off the fixture without pigtailing the wires.
