Need an Alpha Heatsink/Fan combo, but don't know where to get one--HELP!!
CourtDOG
Banned
Oct 3, 2000
62
Well I plan on buying a Athlon T'Bird Processor and overclock it on my KT7-Raid MB. At first I was going to buy a Global Win FP038 combo to cool this baby, but then more and more people told me that the Alpha Pal3065 with a Delta 38cfm fan was better, so I would like to buy one of these, but does anyone know where I can buy one from a web-site online??? But isn't the Alpha 6065 the newer model, or is the 3065 an older, inferior model compared to the 6065??
Plus, if a site accepts Pay Pal that would be great.
Thanks everyone
GT1999
5,261
<< The Alpha PAL6035 with revised clip for the Socket A CPUs, thermal compound, and the highest output 60mm fan currently available. What more can you ask for? >>
Alpha PAL6035 Ultra Kit
<< This is the Alpha PAL6035 heatsink with revised clip for use on socket A CPUs. Also included is a 23.5cfm Sunon 60mm fan and a packet of silicone thermal compound. All hardware is included to mount the fan and install this heatsink on your AMD Duron or Thunderbird. >>
Alpha PAL6035 Kit
I wouldn't recommend the Ultra kit mainly because the Delta Black Label 60mm fan is extremely loud, and most people don't like it. I personally do not mind it, but imagine one of the loudest little fans on the face of this earth and that's about what it is. 2Cooltek is a great place to buy. If you have another other questions he'll answer them for you usually very quickly. Here's Ian's email address.
G|T
