Nvidia gtx260 216!!!
I was cleaning my video card and accidentally ripped the fan power cord while trying to remove the heatsink fan from the shroud cover. Now I need an aftermarket cooler, and I need suggestions because I've never looked into buying one before.
I've got an Antec 900 case with 2 front intake fans, 1 side intake fan, one rear exhaust, and the massive exhaust fan on top of the case as well. My PC is pretty standard, 1 dvd drive, 1 hard drive, and video card. I've also got a Noctua N12P Heatsink/Fan keeping my CPU nice and cool. No other peripherals inside the case aside from the PSU.
Here are my concerns/criteria:
1. While ventiliation is not an issue with my case, I'm somewhat anal/skeptical about getting an aftermarket cooler that will not exhaust the GPU heat to the outside of the case. I'm not against it, but I do like to heavily overclock my CPU and RAM and Ido not want that adversly affected. So I'd prefer a cooler that will still rear exhaust, although if enough people on here say not having a rear exhaust shouldn't affect other peripherals given my situation I will take that into consideration. I've seen some aftermarket coolers that use the side intake on a case as an exhaust, so I will consider that if it is a viable solution.
2. I want a more effecient and quieter cooler than the stock cooler that was on my card.
3. I want the cooler to be compatible with a future upgrade.
4. I'd like to stay under $60 if possible.
5. I don't think I'm ready to upgrade, so please don't recommend that.
Suggestions please and thanks for the help.
