Originally posted by: BG4533
Any third party software is going to read from the same sensors as well, and should give you similar readings. You can buy external temperature sensors that you can where you want to measure the temps, but they ofter read a bit low because it is difficult to get them close enough to the inside of the processor for accurate readings. I would just recommend comparing your temperatures to those of other who have the same mobo. Sensors are usually pretty consistant between boards.
Brian
