I have a friend that has a new W98se system (that I built for him) and is having trouble with his cable
internet connection(USB nic). When I installed it it was fine. Easy install of AT&T cable. The problem is that it
seems to be loosing its ability to connect. For example, will be fine at at night but the next morning not
able to connect. Now I know that is not much info to go on but its all I have at this point. He did have a AT&T tech come out and he said that a reinstall of W98 was needed. ???? Might just be an easy out for the tech????
My thinking is that it is just a W98 Networking issue and simply uninstalling and reinstalling Microsoft
networking and then AT&T software may clear this up.
So I guess whet I'm looking for is the general networking requirements of cable internet (dial-up connection is all I'm familiar with).
Any info, advice, techniques would be great.
Thanks.........
Thanks.........
