Need advice/Recommendations.
Nov 28, 2004
75
My Power supply went out, and took most of my computer with it. I am trying to turn this tragedy into an excuse to upgrade. With a budget of $1,100 I would love advice on the following parts:
Mainboard
CPU
Ram
Video Card
This will be mainly for gaming, but I probably won't be overclocking. I have the parts I need to build what I want except for the items above taken from my Previous System or already purchased trying to get it to work.
Anubis
78,712
427
tbqhwy.com
id go with a 3500+
mobo for the 3500+ just choose any you like feature wise seeing as you arnt overclocking
6800 GT
512 of PC PC4000 ram, get a GIG if you have enough money
Nov 28, 2004
75
Thanks for the great suggestions. I have one more question about ram. I have 1gig(2x512) of Corsair TwinX 3200LLPT already available. Will this ram work with an AMD 64 3500+, and the Asus A8V-Delux MB? If I am reading other posts here right, in the past that memory was a major issue for AMD, but with the Socket 939 that seems like it is not quite the problem it once was. That would save me about $200 I guess. I could probably use that to go from the 6800GT to the 6800 Ultra.
ts3433
2,731
You don't need to get extra RAM then, unless you do really memory-intensive things where you'd want a couple gigs. The PC4000 stated above won't do you any good unless overclocking. The 6800 Ultra is kind of a waste, though--buy the BFG GT (many BFG cards now come pre-overclocked and with a lifetime warranty at those speeds, their 6800 GT no exception) and you're almost at Ultra speeds from stock, with a warranty.
From your previous system:
"PSU: JGE-450P4 450watt Powersupply"
I'm not familiar with this, but it sounds like it might be a generic. Make sure you don't skimp on the PSU this time around, if you happened to before. (That said, you don't need a $180 PCP&C 510W--a quality 350W-450W will be good, from Antec/Enermax/Fortron/Seasonic/OCZ/those kinds of companies. Something in the higher end of that spectrum will be needed if you plan to do SLI in the near future.)
WW2Planes1
172
Have you considered going PCI-E (and maybe SLI)? if you're spending $1,100 for CPU, Mainboard, RAM and Video, you might be able to afford it. When are you planning on upgrading again?
Asus PCI-E boards should be arriving soon... GameVE claims they'll be shipping an Asus-SLI board Dec. 10. (though... It's kinda expensive). Hopefully the price will drop quickly on that... but there'll be other models w/o SLI that might be worth looking into as well.
jterrell
559
The best advice is the hardest to accept, wait a month.
The nf4 boards will be out by mid-december but prolly not readily available til late December/Early January.
1100 can go along way on those 4 components, especially since you have memory that is fine.
You could get the 250 or so SLI mobo and 2 6600 GT pic-e boards(380 bucks) with plenty left over to spurge on a stud processor if you wanted or a 3500+ and another gig of that ram.
