As the title says, I'm deciding between a 1gb 6870 and a 2gb 7850 as an upgrade from my 512mb 4850. I'm not a huge gamer, but I like to play SC2, Diablo2, Skyrim (occasionally), and also my current card is hot/loud as hell.,
From what I've seen, the 7850 at stock is roughly 20% faster/better than the 6870
6870 for $136.49 at Amazon (http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER)
7850 for $209.99 at Newegg (http://www.newegg.com/Product/Produc...82E16814150608)
My dilemma is that I don't really need the 7850 for the games I play, but it might be a good idea to pay a bit more now so I don't have to upgrade as soon. Not to mention the 7850 should be cooler/quieter. However, as you can see, my current card is >4 years old, so I would probably be ok with the 6870.
My order of preference would probably place Performance/Price/Temp/Noise as roughly equivalent.
Anyone have experience with these cards (both the model and specific cards) and want to comment and help me decide? Is the 7850 really worth the extra $70? Or I could even wait for the 7850 to drop in price if it's within the next couple months. If you think I should buy a completely different card, that works too.
Here are my other parts
Phenom II x3 720
8gb DDR3
PSU (to be upgraded no matter which card I pick)
1680x1050 resolution monitor
On a related note, the PSU I'm planning to get is OCZ ModXStream 700w (49.99 at amazon). I'm not going for top of the line, and it seems to be the best in the pricerange. Any other options you prefer?
Thanks for your time
Phenom II x3 720
8gb DDR3
