One of the best bang for buck CPU's at this moment. Great OC'er.
Personally, I'd go the 90nm route unless you have super cooling for the Claw. They are toasty sunsaguns....I had one of those 3500+ Claws which ran nearly 60C under load and yes, case and cpu cooling was adequate.
