* Need advice, Program or script : for quick switching screen resolution and enable/disble screen saver
jimmyhaha
2,851
Greetings
Post in video forums, got no help there.
Need advice, Program or script : for quick switching screen resolution and enable/disable screen saver
instead of going to control panel -> desktop -> scroll through all the setting ?
i.e. when playing movie on tv-out.
Pls advice,
Thanks in advance.
morkinva
3,656
I don't know about the screensaver, but in the DISPLAY PROPERTIES - SETTINGS - ADVANCED of win98, you can check 'show settings icon on taskbar' from which you can right click the icon and set your rez
jimmyhaha
2,851
Thanks for your prompt advice.
However, that's the standard method.
I am looking for a better one, preferably with 1 mouse click only via some sorts of Program or script instead of windows build-in function, aka
