- Nov 10, 2006
- 31
- 0
- 0
So ive jumped on the opteron 165 band wagon. I had an athlon x2 3800 that i had clocked at nearly 2.6hz with no problem. I figured if i could get the 165 to the same speed being that it had a bigger cashe size it would perform better. I've got it clocked at a little over 2.5ghz. it will run 280X9 with nearly stock vcore. when i try to increase the fsb to 290 it wont post. I tried increasing the vcore to 1.42 but it wouldnt post and i didnt want to higher the vcore because i figured it was my ram timings that were holding me back not the vcore.
here my system specs
Asus A8N-E
Opteron 165 @ 2.5 ghz
EVGA Geforce 8800GTS
300 GB Sata HDD
2 X 1 GB Corsair PC3200
Antec 550W Smart Power Supply
I'm only using conventional air cooling. The processor even around 2.5 ghz only read 35C in bios so im figuring that heat isn't going to be an issue. I have good circulation in my case and my basement is cold. Here are my BIOS settings im interested in any feedback i get from more experienced overclockers.
CPU FSB FREQUENCY-280
PCI-100MHZ
CAS-3
TRAS-8
TRP-3
TRCD-21
TRC-16
TRFC-22
TRWT-2
TREF-16
TWCL-1
Thanks Fellow Computer Enthuasists!
Asus A8N-E
300 GB Sata HDD
PCI-100MHZ
CAS-3
TRAS-8
TRP-3
TRCD-21
TRC-16
TRFC-22
TRWT-2
TREF-16
TWCL-1
