Need advice on wireless routers@!
Postumus
I'm just wondering if a plain 4 port wireless router such as the SMC 7004VWBR allows you to connect a mix of wireless and non wireless computers. Basically I'm a lil confused as to what they mean by 4 port, is that 4 ports only for wirless or can you mix and match wireless with non wireless. I can't seem to find a pic of the back of any of these routers so I figured I would post here for a quick response.
Thx !
I have this SMC 7004VWBR and the 4 wire ports are used for my desktops . I also use 2 others laptops with wireless pc cards and they all in the same sub net in this mixed wire & wirelesss configuration . Probably if you had a plain hub, you can plug it into one of those Lan ports and expand them out for more wire ports . Not sure of how many clients ( wire & wireless ) that this router can support though !
