Need advice on upgrading.
Balmhood
36
Hi all,
I am planning to upgrade an old k6-2 computer I have.
I would like to spend around $200 - $250 for the mobo and processor.
I heard about several type of celerons and I am not sure which to purchase with which motherboard. Athlon still seems a little expensive if I want the Via KX 133 chipset.
Any input would be very much appreciated.
Thank you in advance
Balm
Electric Amish
23,578
For that price, you'll probably be stuck in the Celeron bracket, unless you wait for the KT133 chipset for the AMD Duron.
Duron is faster than the Celerons.
For Celerons, I like the Abit BM6 motherboard. You can find it online for $90-$100 USD.
amish
Ulysses
2,136
Yes, honestly, your budget is too limiting right now. But that may really be a good thing. Recently there have been several new platforms announced and in production. but not available yet in the marketplace in quantity. With limited quantities the prices are likely to be high. As a little time goes on the prices will come down a bit and the manufacturers can fix any bugs. So waiting will actually be good.
I would strongly urge you, then, to wisely wait and save your money for the following:
1. Plan to get an AMD Duron processor in Socket A format - they are less expensive than the new Athlon Thunderbirds but will outperform the new Intel Celeron II's (which admittedly will probably be a bit cheaper). The plus is that you can later replace the Duron with a faster Thunderbird if you want to.
2. Plan to get a motherboard based on the VIA Apollo KT133 chipset and with a Socket A connector for the Duron or Athlon Thunderbird CPU. Don't get a mobo with a KX133 chipset or Slot A connector - they're yesterday's newspapers at this point. Watch AnandTech for a 'Roundup' of VIA Apollo KT133 boards some time in the future. AnandTech is tops for this kind of information - their reviews are kind of nerdy and way too long, but their conclusions and recommendations are reliable.
3. Plan to get as much RAM as you can afford - at least 64 MB, and preferably 128 MB. Be sure to get what is known as PC133 SDRAM. If you have PC100 SDRAM now it can still be used in the mobos I've specified to tide you over until you can upgrade to PC133.
Such a system will be a fine performer and likely have a longer useful life than others that are available right now too.
While you are patiently biding your time, read up on this stuff by visiting sites like AnandTech or Tom's Hardware, etc. If you get confused by all the choices (and who doesn't), try to review my recommendations above which can act as an anchor.
Good Luck.
:p
P.S.
Watch AnandTech for their monthly Value Systems Buyers Guide articles. They only recommend hardware you can actually buy at the time. I think they will soon be recommending specific hardware of the type I've spec'd above.
glp1del
I agree with Ulysses; however, depending on what is in your system now you may want to just upgrade the CPU. You can find K6-3 upto 450mHZ and the K6-2 goes to 550mHZ. Depending on the speed of your current system this could be a good way to go until the socket A boards and processors are massed produced.
Glp1del
Balmhood
36
Thanks a lot guys. I think I will follow your advices and keep saving a bit to get me something really neat when they come out.
Duron does sound very nice.
Once again , thank you for everyone's advice :)
Balm
