Id like some advice and suggestions please. I'm going to be building a new rig for gaming. I was planning on waiting a couple months for the new nvidia mobos and then grab a conroe chip. However my current game rig has decided to give up the ghost and my plans need to be stepped up. I am thinking of going with a less expensive CPU/Mobo for now then switching it out for conroe by the end of the year. Heres what I have so far:
nec 3550a burner
http://www.newegg.com/Product/Product.asp?item=N82E16827152058
seagate SATA HD
http://www.newegg.com/Product/Product.asp?item=N82E16822148105
Enermax Whisper II 535W PSU
http://www.newegg.com/Product/Product.asp?item=N82E16817103512
saphire x1900xt video
http://www.newegg.com/Product/Product.asp?item=N82E16814102025
2GB Patriot Ram
http://www.newegg.com/Product/Product.asp?item=N82E16820220095
Windows XP pro
http://www.newegg.com/Product/Product.asp?Item=N82E16837102062
I need suggestions for a mobo/cpu combo. I want to spend as little as I can at the moment and still get decent gaming till I get the conroe. I was thinking of going with a celeron like:
http://www.newegg.com/Product/Product.asp?item=N82E16819112203
Can anyone suggest a good mobo that will support the items I have listed? Also, does anyone else think that its worth the wait for later conroe mobo's? Or should I just go ahead when the conroe (maybe) becomes available later this week and build? Any help would be greatly appreciated,
*edit* How about an am2 mobo with a 3800 amd64? Wouldnt the same memory work there as well?
Arzon
			nec 3550a burner
seagate SATA HD
2GB Patriot Ram
Windows XP pro
Arzon
