teddymines
We have a small built-in desk in the kitchen, and I'd like to either buy or put together a small system that would fit nicely. The desk measures about 4 feet long by about 2 feet deep. There are 3 drawers under the left side that take up about 1.5 feet, leaving about 2.5 feet of space for the chair. This system will be used for small tasks (email, banking, a budget spreadsheet) so it doesn't need a lot of horsepower. I'm leaning toward a small LCD for display.
The problem is finding a place for the case. If it sits on the floor under the desk, I'm afraid it will get kicked or hit by the chair when it is pushed in. I resist putting it on the desktop because space is premium. The drawers wouldn't work because I'm very concerned about heat buildup (I'd have to add lots of venting, which I don't want to do).
Immediately to the right of the desk is the basement staircase. I was thinking of building a bracket to hold the case on the wall in the staircase adjacent to the desk, and then somehow passing the cables through the wall. Physical access to the PC won't be an issue because this will be an always-on PC with no need for CD or floppy access.
So, has anyone done this with a PC? Also, can anyone recommend a very low-profile case for pre-built (preferably used) PC's?
BTW: Here is a link to a similar desk, but ours has only one set of drawers on the left side. The PC would be mounted on the other side of the wall where that red thing on the desk is.
