A buddy of mine has a 30" HD LCD TV/monitor that he wants to connect his PC to, and needs a cable about 30ft long. The 30" LCD only has one DVI input, which is connected to his satelite receiver; The 30" also has RGB, component, S-video, and composite inputs. His video card has DVI, Svideo, and RGB out. If he runs the DVI cable to his 19" LCD monitor at his PC, can he split it to make the long run to his 30" LCD (and split again at the 30" LCD)? Or should he just run the RGB cable to the 30"? Will there be much loss in quality? If he used the S-video out, the max resolution he could use would be reduced wouldn't it?
Can you buy 30ft RGB cables anywhere? All the ones I've seen jump from 25 to 50ft.
