Need advice on replacing dying monitor
spwango
419
I have a 21" Nokia 445Pro (Trinitron), and the screen is starting to destabilize. It will not hold the default screen geometry at most resolutions (it snaps in and out of different sizes/shapes), so it's days are numbered. I'm currently trying to figure out what makes sense for me in terms of upgrading it.
My current system is a socket 754 AMD 64 3000+ with an MSI K8T Neo-FSR, 1 Gig of PC2700, and a Radeon 9800 NON Pro...
I play mostly shooters, Q3, Halflife2, UT2004, Far Cry, Etc and do a lot of text-based work as well. I want either a 21" CRT or a 19" LCD. I'm currently leaning towards the ImageQuest L90D+. If I go down this road, am I going to be forced to upgrade my machine to push a higher resolution? If so, what should I do about that? Just go buy a faster AGP board or rebuild the whole system for socket 939 and PCIE?
Thanks for any advice
ribbon13
9,343
NEC\Mitsubishi FP2141SB-BK or the L90D+ would be excellent choices.
If you want to support the next gen 939 processors, upgrade everything. Otherwise buy a new vid card. If you do upgrade to 939, I suggesting an ATi X800 XL, especially if you get the L90D+. At its resolutionm you should ge good to go for quite a while.
spwango
419
Is it foolish to buy an AGP board at the moment? I'm mostly happy with my rig with the exception of my video board...it really could use an upgrade...does anyone make a decent socket 754 mobo with PCIE?
